| Product(s): | OpenBuildings Generative Components | ||
| Version(s): | Connect Edition update 9 | ||
| Area: | General |
How to get the corner points of any Solid block using Generative Components?
By getting the corner points of the solid, it will help you to get the coordinate of the points that way we can get the set of high points of the solid so as the low points. Please have a look at the below GCT file while will help you get the points very easily. A GNT node has been created for the respective high and low points of the solid.
communities.bentley.com/.../Get-corner-point-_2D00_-GC-Backup-01-_2800_Newest_2900_.gctcommunities.bentley.com/.../Solid-Corner-Points.gcp
