| Product(s): | OpenBuildings Generative Components | ||
| Version(s): | Connect Edition | ||
| Area: | Geometry Node |
With the new release of OpenBuildings Generative Components update 9 we can see that there is a new node type named Parametric cell, which will help us to place and manipulate Parametric cells inside Generative components. Look at the below video to understand the workflow.
