Bentley Raceway and Cable Management is a valuable productivity tool for companies that design, model, and document complex cable and raceway systems for power, process, manufacturing and other complex facilities. It automates manual and error-prone tasks including designing and modeling electrical raceway systems.The product includes Bentley PowerPlatform CONNECT Edition technology and operates in conjunction with Bentley ProjectWise to facilitate the design workflow and manage technical information
This WIKI articles provided in this section provide useful resources for the Bentley Raceway and Cable Management CONNECT Edition. The WIKI is intended to provide instruction in the following areas:
Here you will find brief description for tools and the best way to use them:
https://www.bentley.com/en/perspectives-and-viewpoints/topics/tech-talk/2019/tech-talk-benefits-of-using-bentley-raceway-and-cable-management-connect-edition
Visit Bentley Plant Official YouTube Channel - Click below button
Like Subscribe Share
External Links
Check Learning Content - LEARN Server
