The following items summarize the new features and enhancements in the OpenPlant Modeler CONNECT Edition Update 6 release.
| Version(s): | CONNECT Edition 10.06.00.23 Update 6 |
| Environment: | Windows 10 (64 bit) |
| Area: | What's New |
| Subarea: | - |
| Original Author: | Bentley Product Advantage Group |
| Feature | Description |
| Reports |
| Bolts and Gaskets | Added options to hide bolts and gaskets using the Constructions option via View Attributes. |
| Structural Snap | The Structural snap option is set to "Off" by default. |
| Background Maps | Added support for Background Maps via the View Attributes menu. |
| Piping Supports Tab | The items previously listed under the Piping Supports tab have been moved to the Piping Tab > Piping Galleries group. |
| PlantSight | IModelHub has been rebranded to PlantSight in the interface as well as the respective dialogs, messages etc. |
| Check in Comments | Implemented the option to add comments for Check-in/Update changes to PlantSight. The following configuration variable can be used to toggle the display of the dialog:
"IMODELHUB_NO_COMMIT_MSG=1 " |
communities.bentley.com/.../what-s-new-in-openplant-modeler-connect-edition
