Applies To | |
Product(s): | OpenPlant Modeler CONNECT Edition |
Version(s): |
10.11.00.260 and above
Environment: | Windows 11 (64-bit) |
Area: | Customization |
Subarea: | Schemas |
Original Author: | Sameer Bagwan, Bentley Global Technical Support |
This document shares the reason for missing bolts for Wafer Lug type Butterfly valve and also a way to resolve it.
Problem Description
- In OOTB workset place a Valve with WLUG end preparation and place two flanges on each side.
- Notice that bolts are not getting placed.
- This is because OOTB mCS150 spec doesn’t have BOLT and MACHINE BOLT in spec, instead it only have STUD BOLT as seen below.
Steps to Resolve
- Add new record entry for BOLT and MACHINE_BOLT as per the standard dimensions in the spec for testing lets copy any existing record and rename its EC_CLASS_NAME as BOLT, MACHINE_BOLT.
Also its description can be changed as per standard definitions.
- Verify the results in the OPM.
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
