OpenPlant Modeler CONNECT
OpenPlant CONNECT Edition
Work remotely or connected with the market's most productive and easy-to-use 3D plant design and modeling software
OpenPlant Modeler CONNECT Edition, the first 3D plant modeling software based on ISO 15926, is an accurate, rapid, design engineering solution for 3D plant design. It enhances project teams with mobile information, i-models, and support for multiple formats and data types, such as DGN, DWG, JT, point clouds, and PDF, to provide flexible design and review processes. It is both more versatile and productive than any existing "3-D piping" application. The OpenPlant Modeler CONNECT Edition includes SELECT CONNECTservices, new Azure-based services that provide comprehensive learning, mobility, and collaboration benefits to every Bentley application subscriber Optional Pre-requisite: Structural Synchronizer is required for ISM data interchange workflows only. For information on system requirements, licensing, and what's new in this release, see ReadMe document.
LICENSE USE
CONNECT Licensing: This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization's user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
You can find these builds on Software Downloads:
TECHTALK - New
Visit Bentley Plant Official YouTube Channel - Click below button
Like  Subscribe  Share
FIRESIDE CHAT- New
From Mouth of Product Management - Click Here >>>
www.youtube.com/watch
Fireside Chat: OpenPlant CONNECT Edition Update 8
OpenPlant Modeler v8i
External Links
Check Videos  ContentLEARN Server
learn.bentley.com/.../ViewLearningPathWithMasterCourseExpanded
Comments or Corrections?
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
