About OpenPlant PID - CE
OpenPlant PID CONNECT Edition is built on the ISO 15926 data model, signaling the next step in plant software development. Now, any application that is mapped to the ISO 15926 schema can natively interoperate with OpenPlant PID. This means any data created in OpenPlant PID is available to be shared without the need for complex APIs. OpenPlant PID CONNECT Edition includes SELECT CONNECTservices, new Azure-based services that provide comprehensive learning, mobility, and collaboration benefits to every Bentley application subscriber. For information on system requirements, licensing, and what's new in this release, see the ReadMe document.
LICENSE USE
CONNECT Licensing: This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization's user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
SUPPORTED OPERATING SYSTEMS - Windows 10 (64-bit), Windows 8.1 (64-bit), Windows 7 (64 bit)
You can find these builds on Software Downloads:
TECHTALK - New
Visit Bentley Plant Official YouTube Channel - Click below button
Like  Subscribe  Share
FIRESIDE CHAT- New
From Mouth of Product Management - Click Here >>>
www.youtube.com/watch
Fireside Chat: OpenPlant CONNECT Edition Update 8
OpenPlant PID v8i
External Links
Check Videos content- LEARN Server
learn.bentley.com/.../ViewLearningPathDetails
Comments or Corrections?
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
