OpenPlant Isometrics Manager CONNECT Edition is the first software to extract intelligent isometric information from any design system’s 3D model, and do so automatically and in real time. It provides management control capabilities for pipe models and isometrics from OpenPlant, Bentley plant products, PDMS, SmartPlant and PDS. OpenPlant Isometrics Manager CONNECT Edition includes SELECT CONNECTservices, new Azure-based services that provide comprehensive learning, mobility, and collaboration benefits to every Bentley application subscriber. For information on system requirements, licensing, and what's new in this release, see the ReadMe document.
LICENSE USE
CONNECT Licensing: This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
You can find these builds on Software Downloads:
TECHTALK - New
Visit Bentley Plant Official YouTube Channel - Click below button
Like Subscribe Share
FIRESIDE CHAT- New
From Mouth of Product Management - Click Here >>>
OpenPlant Isometrics Manager v8i
Check Videos Content - LEARN Server
learn.bentley.com/.../ViewLearningPathDetails
Bentley Product Advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
