| Product(s): | OpenPlant PID |
| Version(s): | CONNECT Edition (10.11.00.260) |
| Environment: | Windows 10/11 (64 bit) |
| Area: | Class Editor |
| Subarea: | Schemas |
| Original Author: | Chanchal Mashalkar, Bentley Product Advantage Group |
While loading OpenPlant_PID schema or supplement the schema, class editor asks to locate a missing reference file and shows below file open dialog:
Basically when any project/workspace schema is loaded in class editor it references in various schemas but when the location of reference schema is not found then it shows the above dialog.
You need to add the location of these schemas in class editor once and it will automatically reference in the schemas from the next time and won't ask for the location. Follow the steps below to resolve the issue:
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
