| Version(s): | CONNECT Edition 10.11.00.260 & Above |
| Environment: | Windows 10/11 (64 bit) |
| Area: | OpenPlant Modeler Specification Generator |
| Subarea: | Customization |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
To define branch code for desired piping component in OpenPlant Specification Generator.
User wants to define branch code for desired piping components so that he need not to define branch code through Specification Generator. This can be achieved by defining default branch code value to desired component. As an example, below article describes how to define branch code to inspection tee.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
