How to Cascade Actuator Label Display From Control Valve to Bubble Annotation in OpenPlant PID Conne
Product(s):OpenPlant PID
Version(s):CONNECT Edition (10.11.00.213) & Above
Environment:Windows 10/11 (64 bit)
Area:Schema Customization
Subarea: Bubble Annotation
Original Author: Chanchal Mashalkar, Bentley Global Technical Support
Requirement is to populate Actuator Display Label from control valves on bubble annotation placed on it. This can be achieved by making changes into the schema using class editor. Please refer below snapshot.
  1. Launch class editor and load OpenPlant_PID schema.
    Navigate:C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\OpenPlantExample\WorkSets\Metric\Standards\OpenPlant\Schemas
  2. Supplement it with OpenPlant_PID_Supplemental_Design.01.08.ecschema
  3. Go to INSTRUMENT_ANNOTATION class and switch to properties tab.
  4. Add new property on this class.
  5. Name the property as you like. For example, name it CRM_ACTUATOR_DISPLAY_LABEL as shown below.
  6. Select BUBBLE_LOCATION property and copy 'Category' custom attribute.
  7. Select CRM_ACTUATOR_DISPLAY_LABEL property and paste the custom attribute.
  8. Go to INLINE_CONTROL_VALVE class and switch to Properties tab.
  9. Select DEVICE_TYPE_CODE property and copy "Notify Related Component of Property Value Change"
  10. Go to INLINE_CONTROL_VALVE class and override ACTUATOR_DISPLAY_LABEL property.
  11. Paste the custom attribute on this property, which was copied in step 9.
  12. Change the target property name in the custom attribute to CRM_ACTUATOR_DISPLAY_LABEL as shown below.
  13. Save the changes in schema and load OpenPlant PID to verify the result.
    Note: If you want to see the actuator label on all types of control valves, then you will to perform step 8 to 12 for all control valve type of classes.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0097337
Still a Problem?
Comments or Corrections?
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
