| Applies To | | |
| Product(s): | OpenPlant Modeler Connect | |
| Version(s): | 10.11.++ | |
| Environment: | Windows 10 (64 bit), Windows 11 (64 bit) | |
| Area: | Supports | |
| Subarea: | Modify | |
| Original Author: | Joseph Gelacio, Product Advancement Group | |
To edit Saddle Support Clas
- Open the OpenPlant_3D.01.08.ecschema.xml in the class editor and supplement with the OpenPlant_3D_Supplemental_ModelingViews.01.08.ecschema.xml schema.
- Navigate to Support class and select support. For example Pipe Hanger
Check custom attribute property IGNORE_PIPE_SLOPE_ON_SUPPORT. Select its value as False from drop down. For example,
Note: Set IGNORE_PIPE_SLOPE_ON_SUPPORT= True if you want to keep the support vertical on placement and apply slope. Or delete the custom attribute.
Note: By default IGNORE_PIPE_SLOPE_ON_SUPPORT= False for Anchors, Guides, Support Locators. These Supports are aligned with both Horizontal and vertical sloped pipes.
- Open a dgn in OpenPlant Modeler . Place a pipe and click on the Supports drop down button on the Piping Galleries tab. And select Hangers. Hanger Components appear in gallery.
- Select the desired Hanger support from the Component Gallery. Standard Preferences for Support dialog appears.
- Select Specification value as Supports from drop down.
- Click on the pipe you want to place the support.
The Place Support dialog box appears.
- Select the" Location" and "Rotation" Points and click left. The support component gets placed and is aligned with pipe.
- Apply some slope to the pipe using Apply Slope tool. For example 5 degrees. Hanger support get aligned with both Horizontal and vertical sloped pipes.
communities.bentley.com/.../how-to-show-imperial-metric-sizes-in-the-same-project-in-openplant-pid-connect-edition
