Resolved Issues in Bentley Raceway and Cable Management CONNECT Update 9 (10.09.00.74)
IDTitle
182439After removing design files from ProjectWise and refreshing the Collaboration Manager the files are not removed from the list of resources.
182402Automatic routing on raceway with multiple divider sections of the same voltage level only fills one of the sections.
181930[BESM] The Support Width and Primary Size units cannot be converted automatically in metric system (according to design file unit)
182376Duct bank section graphics text "Is Annotation" setting was not set properly resulting in wrong text sizes.
173406[Raceway Router]Modify UDAs of existing raceway catalog, the UDAs cannot display in the Raceway Routing Tool/Start dialog in time.
173409[Place Equipment]The equipment name loses the leading zeros if setting the Start value as 001 and placing multiple equipment.
444531BRCM CE Russian | Raceway is not properly modeled for DKC Cable Ladder Combitech Catalog.
448898BRCM CE U4 | Cable entries get duplicated in Raceway fill info dialog.
393494BRCM crashes after acknowledging the deleted cables
279101BRCM Crashes with no error after running reports if any part/fitting from the raceway catalog is removed.
296242Annotation scale settings should apply to the 2D extraction graphics if equipment 2D cell is set as annotation cell.
483834While using 2D Extraction for the cell based equipment the software would apply an offset and scaling that wasn't desired in some instances.
535171Incorrect Voltage Level assigned to the Vertical Bends after generating concrete for duct bank conduits.
287399Copy Manhole does not delete trimmed ductbank concrete elements.
268121Level Display does not auto refresh when Filter is used
281273[Equipment Properties: Component Center] Instead of showing Properties of already placed Equipment, Equipment Properties dialog shows the new default properties and apply them to the selected component when click "OK"
310855Placing supports in file gives an error and crashes the application in a workset created from OPPA
362569The item browser is not Showing the ECproperties data for cable.
369932[Cable Manger] "Filter Cables with Same Terminal" takes a long time to execute.
370000[Cable Reports] Upload to Projectwise message appears on creating Cable Drums even when working with a local WorkSet.
440764[Cable Manager] Performance issue with larger number of cables and Equipment
414433Duplicate BRCM_DB_ID is created when creating projects in OPPA
286480The BRCM_DB_STATIONID variable should be set to the user's machine name.
449221[integration with OPM] Wrong dataset Version in Configuration_Properties.cfg file
454497[Russian Build] Raceway Router is not working in Russian Build with Russian Regional Setting after Updating dataset
317669In some cases the 3D cable generated was not continuous.
317670After 3D cable was generated in a particular instance the cable length was not correct in the cable manager
317671Under certain conditions the 3D cables generated were not smooth.
3176723D cables lay out improperly on a vertical fitting
352380If importing cable types with excel that had the same name but with different upper and lowercase letters it would import them both rather than recognizing them as duplicates.
286056Locking a resource in the Collaboration Manager using the ID Manager is not setting the Action field to ID Manager
509841Wrong Concrete Material Volumes calculation in Metric dataset
385479Inserting a Manhole in a Ductbank does not delete all parts inside the manhole.
448771Performance Issue - Check Routing Connectivity Tool was slow to execute in certain scenarios.
365450Using the ID Manager to Move IDs requires the user to select the destination equipment two times and there are no prompts
504864Importing a database backup resulted in incomplete naming in the location cable property shown in the Cable Manager.
519019Collaboration Manger shows all revisions of the same DGN rather than just listing the latest.
454175Raceway Connectivity Tool falsely reports that there is no raceway connectivity when in fact there is.
392275[OPM Integration] We should remove drawing types that are not required from the Document Manager inside of OpenPlant Modeler.
357640[Integration with OPM] Equipment Properties command is not working
523360The 3D cable generated inside of a Trench  didn't follow the routing line.
523486[Raceway Size] Raceway Size Command did not work in a particular file that contained mismatched variant and routing line GUIDs.
544149[Raceway Routing] Automatic Raceway part placement is not working for Cable Basket in Imperial Workset
548975One of the metric sample models reference DGN had embedded schemas
535152Conduit IDs did not get assigned after generating concrete around a placed branch of duct bank.
