| 373888 | Inserting a Part into a conduit caused a gap and loss of connectivity | Raceway Router |
| 1007861 | Multiple Raceway Segments could not be routed using existing configuration. | Raceway Router |
| 967604 | The Insert Raceway Part feature was not previewing the part at the cursor. | Raceway Router |
| 1009201 | The default size of the Routing Preferences dialog was chopped off and needed to be manually resized to see the controls. | Raceway Router |
| 1013561 | The Raceway Router only allowed me to define a single virtual connection before ending the command. I should be able to place multiple virtual connections. | Raceway Router |
| 966987 | The Raceway Size dialog contained invalid entries for concrete, duct bank, and trench which did not apply. | Raceway Router |
| 306109 | After using the place part function to insert a pull box at the end of a conduit the software crashed. | Raceway Router |
| 170539 | Default setting for Accessories in BOQ should be set to NO. | Raceway Router |
| 179775 | In certain scenarios, the Raceway Label tool would not always open, such as in an isometric view. Also, section cut placement could have a flickering issue when stacked raceways are present. | Raceway labels |
| 1008120 | After using the Raceway Generator to convert lines and arcs to raceways and then using the Raceway Offset command to offset the raceway system the software would create an overlapping raceway system rather than offsetting it according to the offsets you specified. | Raceway Offset |
| 1009756 | The software crashed when you clicked on the Support Manager button when using the old BRCM CE project/workset. | Raceway supports |
| 999643 | The raceway support tools were not functioning. | Raceway supports |
| 1005311 | Specifying a start ID of 0001 in the Raceway ID dialog results in an ID of 00010 rather than 0010 once you reach 10. | Raceway ID |
| 1005799 | There was no alert message when you attempted to save a raceway label configuration to a dataset folder that was read-only. | Raceway ID |
| 980438 | When a Manhole is placed across the Duct Bank the conduit did not get cut inside of the manhole. | Ductbank |
| 983465 | When a manhole was placed over a duct bank with concrete, the center line for the duct bank did not get disconnected in between the manhole. | Ductbank |
| 804622 | The wrong fitting position/orientation resulted from using Cursor Position with Duct Bank routing. | Ductbank |
| 949554 | When terminal connections were renamed the equipment became dissociated. | Equipment ID |
| 966476 | The Equipment Manager could not place the insertion point when modifying an existing piece of equipment. | Equipment Placement |
| 1023973 | After creating a cell-based equipment and adding a new UDA, it displayed the 3D cell name rather than the UDA value itself. | Equipment Placement |
| 958017 | The Equipment name changed from a Chinese name to an English name when the equipment was modified in the Equipment Manager. | Equipment Placement |
| 939097 | If you used an invalid xls and xml file when executing an Equipment Import the software crashed. | Equipment Import |
| 945459 | The software could hang up when importing an OpenPlant i-model, removing the imported equipment, and then importing a second time. | iModel Import |
| 1032195 | The mapping for class "VESSEL" was missing from the "OpenPlant_Supplemental_Mapping_BRCM.01.07.ecschema.xml which caused the equipment not to be imported properly from OPM. | iModel Import |
| 1009717 | When an i-model was published there were no relationships between equipment and cables in the master (active) model | iModel |
| 982559 | There was a duplication of cables when reference models are attached to the main files. The number of duplicate cables is equal to the number of reference models attached. | iModel |
| 1025690 | Working in files with a Global Origin other than (0,0,0) resulted in elements being shifted far away from their intended location such as raceway IDs and duct buck concrete. | File Settings |
| 944952 | Certain raceway fittings (i.e. elbow) were not displayed correctly using a Wireframe display style. | File Settings |
| 1019072 | If you performed an update install, the SQL login information in the BRCM.cfg file was being overwritten. | Database |
| 931235 | Datasets were not being backed up prior to uninstalling the software. Now the software will not remove custom files that were added or modified after the original installation. | Dataset Upgrade |
| 1032334 | The Schema files did not get updated while updating the Dataset due to which the customizations done by the user were not migrated to BRCM CE. | Dataset Upgrade |
| 1031706 | A prompt was added to restart the software after successfully upgrading a dataset. | Dataset Upgrade |
| 1001950 | When trench was routed and placed Chamfered Bends using place part, some of the supports were not placed correctly on the Trench inside wall. | Cable Trench |
| 1027944 | If you configured a new Cable Type XML file using the + button, the values could not be saved correctly. | Cable List Import |
| 474205 | The cable list import function excluded cables that had no default voltage level. | Cable List Import |
| 999335 | In certain scenarios cables were shown outside the raceway tray when generating 2D Section Cuts. | 2D Section Cuts |
| 1013439 | The Annotation scale for section tables did not work in the DGN file “2DX_US.dgn” of the metric demo project “BRCM_EU_EN." | 2D Section Cuts |
| 923568 | Some of the prompts for the 2D Extraction tools needed improvement. | 2D Section Cuts |
| 999644 | 3D cables could not be generated when running auto cable routing when the Reroute Cables with lower Priority toggle was enabled. | 3D Cables Visualization |
| 995214 | In the Options > CAD Standards > Levels dialog, the Import levels from active file failed to import any new levels in the file you selected to import from. | Options |
| 1018945 | When opening a drawing from a specific project and then trying to load the options dialog a failed to load cable level assignments error was displayed. | Options |
| 1011819 | If you used the Place Shape tool to add a shape to a drawing and you close the drawing and or reopen it the software would crash. | Platform |
| 995909 | If the PW_DISABLE_INTEGRATION_FROM_DESKTOP was set to 0 you were not able to save a raceway configuration in the Raceway Router dialog. An error indicating that the configuration was being edited by another user would be displayed. | ProjectWise Integration |
| 965877 | If you opened a project design file in ProjectWise and then closed it and then tried to reopen it again you got an error that no project was active. | ProjectWise Integration |
| 1024296 | If your project name contained Chinese characters you would get an error message. | Localization |
