Resolved issues in Bentley Raceway and Cable Management CONNECT Update 1, 10.01.00.21
Bentley internal tracking number Item typeDescription
151326DefectConceptual design - i model import
358483EnhancementUpdate help file with supports placement section
358484EnhancementUpdate help file with enhancements in cable management
390678EnhancementRaceway ID: include leading zeros in Start Value
433164DefectLong Cable type doesn´t show Raceway fill and color code
434071DefectAfter click OK in Status Manager, the Node Names in Cable Manager display incorrectly
569700EnhancementSeparate parts on BOQ report by product code (PCode)
613353DefectBlank UDA values, Connect raceway, leads to separate line items on BOQ
616800Defect[CleanupDNAs]Remove not supported DNAVariables from DNA-Files
700357DefectName entry in SPEC_CableFill.xml to long, incorrect raceway fill info
705299Defect[3DCableVisualization] 3D Cables do not take correct path
706233Defect[3DCableVisualization] 3D cables slide of the cable tray and are shown outside of cable tray
706252Defect[3DCableVisualization] 3D cables bend are outside cable tray.
707564Defect[3DCableVisualization] Cannot generate 3D cables visualization for the first time
719343DefectRemove "Reference Height" option from Section cut
857532DefectNew cell-based Equipment without _3D in cellname
887510EnhancementAutomatic routing line placement between cable trays and conduits
894494Enhancement New Cross Section Template for the details Serial No, Cable Number, Cable type, Size and Weight
902290DefectBRCM: Genarating concrete for duct bank with millimeters as MU results in BRCM getting locked up
902905EnhancementAdding BRCM compatibility with Windows Server 2012 OS and Citrix 7.6 Enviornment
905850DefectBRCM: Using a text value for format attribute in CSECTION XML file causes incorrect table generation using that section.
916646DefectImports I-MODEL files to BRCM,if  there is equipment on the drawing , then BRCM can not read any I-MODEL information
923688Defect[Create New Raceway Catalog] It should give clear prompt when remove Value under the Fittings tab
925800Defect[Publish i-model] The device in published i-model file opened in MicroStation is duplicated
934376DefectiModel publish message
935817DefectZoom and pan commands don't work with equipment placement
935840DefectIncorrect tool focus after RW is selected
937750Defect[Output Manager] Report cannot be updated after update database
939155Defect[Equipment Manager] It crashed when create and place new equipment, then click Equipment Properties to review it
939575Defect[Help] It should display help about the opened dialog while pressing F1
945018Defect[Output Manager] Unhandled exception appears while exporting a report with the same name to replace the opened old report file
947292DefectRaceway variables don't display any Description in Element information for Raceway
948024Defect[RacewayLabels]Duplicated label ‘Catalog Name’ in Metric System
948239Defect[iModel Import] It should give more friendly and clear and consistent prompt when there's no referenced i-model file
952958DefectDefault Cable Layout Method cannot be seen in Element Information for routed raceway
955258DefectEquipment Cursor position snap and zoom doesn’t work
955875Defect[Pre-Check Auto Routing Entry Points ] It should dispay "Equipment With No Autorouting Entry Points" in the title
964408Defect[Publish i-model] There's no relationship under the Cable node for published i-model files
966986Defect[EditFitting] incorrect bend fitting after edit a right bend 90 degree
974533DefectAutomatic routing line is connected from the middle of the conduit
982663DefectBRCM: Duct Bank Generator Bottom Margin gets reset to zero when selected to generate Duct bank concrete
995759Defect[OPSE] The default values of the Trapeze Tray Support are incorrect
995763Defect[OPSE] The Spacing, Minimum Start Offset and Minimum End Offset values of the Trapeze Tray Support cannot be maintained
996196Defect[OPSE] The Center Hung Tray Support units cannot be converted automatically in metric system (according to design file unit)
996530Defect[Ductbank] Bottom Margin of concrete cannot be automatically calculated according to the spacer size
999193DefectCannot Edit bend radius
1004207Defect"BRCM Community" link doesn't work for BRCM CE
