ID | Description |
390057 | The Cable Sizing function executes the change process even though the feature was cancelled. |
473423 | After creating a detailed cable info section cut the table will reflect the routed cables, but if you remove the routed cables and attempt to update this section cut the table will still list the previously routed cables. |
629813 | We improved the performance of stretching duct bank concrete. |
629820 | We improved the performance of the key in “rcmfixductbanknamedgroups.” |
660682 | The trench Route could not connect properly after deleting a trench tee using the ‘Delete Trench’ button. |
660695 | The Trench route could not connect properly after moving a trench crossover using the modify trench command. |
1036777 | When placing equipment from the Equipment Manager, if you changed the insertion point for the equipment it would disappear from the current view and you had to search for the equipment. Now the equipment position should remain within the view. |
1038562 | The cable list importing process did not allow you to enter an "Underscore" for separating the Panel ID and the terminal connection. |
1041017 | The tee fittings in the standard BRCM_PLANT_US_COMP example project did not display a bend radius when you viewed the properties on the fittings. |
1037932 | The Insert Raceway Part feature was not previewing the part at the cursor. |
809117 | If multiple hatches are defined In the Options CAD Standards> Hatches then no hatch was applied when creating a 2D raceway extraction. |
1051380 | The Connect function in ductbank Router dialog cannot be used when ductbank is non-orthogonal |
865428 | While Routing Cable Tray where the Raceway has a Y offset and then Place Part is done for two Custom Vertical Bends the BRCM Software Crashes. |
927190 | When routing a conduit and placing a Tee with ‘left/right direction’ the conduit that continued on the other side of the Tee was at an angle rather than aligned with the Tee. |
965627 | The BOQ of Cable Tray filtered the Tray according to the Drawing Reference for the raceway, but the filtering applied to the Tray only and not the accessories like the Tray Cover and Divider. The details for the raceway cover and divider were listed together with no Drawing Reference Filter. |
1022338 | Annotation scale for the text in section graphics did not work properly. |
1032344 | Copying Duct Bank copied the Manhole or Equipment along with it and the ID for copied Manhole or Equipment could not be edited. |
1034328 | An error occurred saving UDAs when you set # PW_DISABLE_INTEGRATION_FROM_DESKTOP=1 in pw.cfg file for ProjectWise integration. |
956663 | The Weight of cable on drums can exceed the drum's specified Load. |
1031130 | If a Duct Bank design was split across two separate files the Detail_Envelope_BOQ report would not report the IDs. |
1035395 | In the Equipment Manager dialog if the user changed the dimensions of an equipment and saved it as a configuration it would be lost after the Equipment Manager was closed and reopened. |
923570 | Various commands in the Manage ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
923565 | Various commands in the Equipment & Cable ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
923569 | Various commands in the Output ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
923566 | Various commands in the Raceway ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
923567 | Various commands in the Underground System ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
923571 | Various commands in the Modify contextual ribbon menu were not displaying command prompts and would display useless Tool settings dialog boxes. Now these tools have proper prompts and unnecessary dialog boxes are no longer displayed. |
948230 | The Raceway properties were always displaying the units in inches even when using a metric project. |
949623 | The Edit Text command was added to the "Common Tools" panel group in the ribbon menu tabs for "Equipment & Cable," 'Raceway," "underground System," and "2D Extraction." |
1012968 | The MicroStation "Position Mapping" feature was not enabled in Bentley Raceway and Cable Management. Now the feature has been enabled and the settings can be found in File >> Setting >> User >> Preference. |
1045126 | The Bend Radius for T-fitting was 0.0000 in the sample WorkSet BRCM_PLANT_US_WIP. |
1056107 | The Create New Raceway Catalog dialog text controls overlapped each other when Windows scaling size was set to 125% or greater. |
965878 | The Place Equipment tab would flash while clicking the Create/Modify Equipment command. |
983286 | The published i-model could not display the BRCM raceway / device data in the Element Information dialog in Navigator. |
1030765 | When creating a section in a particular project in the Section Properties dialog, selecting the RWLabel.xml file and then selecting OK crashed the software. |
1030685 | In certain circumstances, the Raceway properties were not listed in the Properties dialog until you closed and reopened the page. |
1037198 | The help buttons failed to open the proper help topic in the Options > Cable Data > 3D Cable Levels >and the Options > Cable Routing > Cable Laying Methods dialog boxes. |
1041063 | When doing a Cable List Import from Excel, if you selected the Configuration button and mapped another field and saved that, but then went back into the configuration and removed this mapping it would still remember the previous mapping. |
1033355 | The software crashes when you attempted to copy/move/stretch ductbank with a manhole using the Modify Ductbank tool in a particular file. |
1032472 | Trench supports disappeared after extending the trench. |
1028403 | I the Options > Cable Data if you do an import of a Cable Types and modify the XML mapping file the software failed to save your mapping changes. |
1030489 | In the Raceway Routing dialog the segment label was not correct if setting a Start value=001. The first segment number should be 001 and not 1. |
1031930 | In the Auto Routing Entry Points dialog of the Cable Manager, the Visualize command zoom factor is not appropriate making it difficult to see the drawing as needed. |
1034591 | When an equipment list is imported and an additional column added to define equipment name, that selection is not saved in the XML file. |
1034412 | Duct bank concrete disappeared after using the Edit Manhole tool. |
1036915 | Using Insert Part and selecting a raceway and then closing the dialog without placing a part left the routing dialog open and if you tried to switch to the Element Selection tool it would crash the software. |
1036128 | In the COMOS_SAMPLE WorkSet some raceways had incorrect properties which caused the 3D Cable visualization to generate improper cable routes. |
1037934 | The Insert Raceway Part feature was not previewing the part at the cursor. |
1037935 | The Insert Raceway Part feature was not previewing the part at the cursor. |
1047501 | The file “CFG_UDAs.XML” was overwritten when upgrading datasets from V8i to BRCM CONNECT, so any custom fields were lost. |
1051944 | When you publish an Imperial DGN to an i-model the details of the raceway present in the i-model the dimension units for the Trade Width and Trade Height values are shown in Metric units. |
1053220 | Duct Bank Stretch command doesn't move the horizontal concrete bend correctly. |
1053323 | When publishing an i-model for a DGN which has Custom Raceway & Schemas the custom fields are not shown in the i-model as can be seen in BRCM Element Properties. |
1055808 | Define a new Raceway System for a catalog and then route raceway from this new system. If you then tried to use the Resize Raceway feature on this raceway the software would crash. |
