| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.XX.XX.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
Spindle is the standard label for handwheel in generated isometrics. However, some users prefer to display IE_OPERATOR value (hand_wheel) of the Gate Valve in OpenPlant Isometrics Manager. Kindly follow the steps below to achieve the goal.
1. Open the drawing model and generate isometrics.
2. In isometrics configuration, proceed to User Label.
3. Locate Valve Operator Label and change the Text value.
Text: $$(IE_OPERATOR):$$(IE_OPDIR)
4. Save the changes.
5. Generate the isometrics to verify the result.
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../modifying-the-isometric-content
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
