| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | CONNECT Edition Update 11 (10.11.01.136) & Higher |
| Environment: | Windows 10 (64 bit) |
| Area: | Errors & Messages |
| Subarea: | Iso Extractor - Progress Message |
| Original Author: | Rahul Kumar, Bentley Global Technical Support Group |
In OpenPlant Isometrics Manager, during isometrics generation, Iso-extractor dialog displays error as Failed to read ECSchema...."
In OpenPlant Isometrics Manager, user might receive an error as described below while generating iso's in-session using OpenPlant Modeler.
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
