| Product(s): | OpenPlant PID |
| Version(s): | CONNECT Edition Update 11 (10.11.00.213) |
| Environment: | Windows 11 (64 bit) |
| Area: | Errors & Messages |
| Subarea: | Pipe Run Termination |
| Original Author: | Sameer Bagwan, Bentley Global Technical Support Group |
In OpenPlant PID OOTB ISO Metric workset, placing Pipe Run Termination gives error message and TO/FROM fields dose not get populated
In the OpenPlant PID OOTB ISO Metric workset, an issue has been identified when placing the Pipe Run Termination. An error message (“Nozzle Connection Broken”) is displayed and the TO/FROM fields do not get populated as expected. This disrupts the workflow and could potentially lead to inaccuracies in the piping system design.
Note:
To Resolve the Incorrect Configuration of "Pipe Run Termination" by Adding the Missing Connection Point in the ISO Metric Workset in OPPID
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
