| Product(s): | OpenPlant PID |
| Version(s): | CONNECT Edition Update 11 (10.11.00.213) |
| Environment: | Windows 11 (64 bit) |
| Area: | Tools |
| Subarea: | Component Manager |
| Original Author: | Sameer Bagwan, Bentley Global Technical Support Group |
In the OpenPlant OPPID OOTB ISO Metric workset, the Pipe Run Termination is not configured correctly. As a result, it doesn’t get positioned properly in relation to the direction of the pipe end.
In the OpenPlant PID OOTB ISO Metric workset, an issue has been identified with the configuration of the Pipe Run Termination. The current setup is incorrect, leading to placement issues. Specifically, the Pipe Run Termination does not orient itself correctly in relation to the direction of the pipe end. This misalignment disrupts the appearance and creates overlap.
To Resolve the ‘Nozzle Connection Broken’ Error and Populate TO/FROM Fields for "Pipe Run Termination" in the ISO Metric Workset in OPPID
Still a Problem?
If above problem still persists, then please log a Case and contact the Bentley Global Technical Support group. While logging a case, please include all relevant information to get in-depth analysis for a solution or workaround.
Link to log a case is available Here>>>
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
