| Version(s): | CONNECT Edition Update 11 (10.XX.XX.XXX) |
| Environment: | Windows 10 (64 bit) |
| Area: | Customization |
| Subarea: | Property |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
In OpenPlant Modeler, there is a situation where one of the component properties has no value or missing. In addition, the property is grayed out and unable to put a value manually. For instance, Insulation Material doesn’t have a value and unable to type anything. However, it is possible to gain a value by using the Details button or command.
communities.bentley.com/.../errors-logs-messages-crashes-in-connect---openplant-isometrics-manager
Comments or Corrections?
Bentley's Global Technical Support group requests that you please confine any comments you have on this Wiki entry to Forum section? section. THANK YOU!
communities.bentley.com/.../autoplant-axsys-openplant-plantwise-forum
