Applies To | |
Product(s): | OpenPlant PID CONNECT Edition |
Version(s): | 10.xx.xx.xxx |
Environment: | Windows 10/11 (64 bit) |
Area: | Schemas |
Subarea: | Pipeline Annotations |
Original Author: | Álvaro Melgarejo, Bentley Global Technical Support |
This wiki shows how to create a new pipeline annotation displaying the pipe run's insulation thickness. The instructions written here are valid for creating new pipeline annotations that display any pipe run's property value.
- Launch OpenPlant PID CONNECT Edtition and open any DGN.
- Right click on an empty space in the ribbon toolbar and select "Customize Ribbon".
- On the right-hand side upper box, navigate to:
OpenPlant PID -> PID Gallery Components -> Pipeline Annotations. - Right click on Pipeline Annotations and select Add New Button.
- Select the new button, and on the box below, fill the Key-in field with
pid insert OpenPlant_PID PIPE_LINE_ANNOTATION_ALT8
Note: it might be that PIPE_LINE_ANNOTATION_ALT8 is already in use, if this is the case, use the next available number: pid insert OpenPlant_PID PIPE_LINE_ANNOTATION_ALT#
Customize the rest of the button as desired.
At this point, a button has been created for the annotation, but there still remains to create and configure the class in the schemas. - Open the Windows file explorer and navigate to:
C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\{WORKSPACE_IN_USE}\WorkSets\{WORKSET_IN_USE}\Standards\OpenPlant\Schemas
Or to the location where the OpenPlant schemas are located in the configuration in use. - Open OpenPlant_PID.01.08.ecschema.xml with a plain text editor, Notepad++ is recommended.
- Press ctrl+F and search for BASE_PIPE_LINE_ANNOTATION. Make a copy of the SIZE ECProperty. In the copy, change propertyName to "INSULATION_THICKNESS" and displayLabel to "Insulation Thickness". Refer to the picture below.
- Press ctrl+F again and search for PIPE_LINE_ANNOTATION_ALT2. Make a copy of this ECClass and, in the copy, modify typeName, description and displayLabel accordingly. Refer to the picture below.
- Save and close the schema and open OpenPlant_PID_Supplemental_Design.01.08.ecschema.xml schema.
- Press ctrl+F and search for BASE_PIPE_LINE_ANNOTATION. Make a copy of the SIZE ECProperty. Change propertyName for "INSULATION_THICKNESS" and the DefaultValue for Insulation Thickness. Refer to the picture below.
- Press ctrl+F again and search for PIPE_LINE_ANNOTATION_ALT2. Make a copy of this ECClass. This time, it will be necessary to again correct typeName, and to change the ECExpression for this one:
this.INSULATION_THICKNESS
Additionally, the FailureValue and the DefaultValue can also be changed to Insulation Thickness.
- Save and close the schema. Restart OpenPlant PID.
- Draw a pipe and assign it any Insulation Thickness.
- Click on the button created earlier or insert the Key-in pid insert OpenPlant_PID PIPE_LINE_ANNOTATION_ALT8.
- Place the Insulation Thickness annotation on the pipe and observe it display the correct value.
