如下MVBA代码可以对当前模型重新设置其工作单位(Working Unit)。注意代码结尾处对SaveSettings的调用很重要,否则设置的工作单位将不被保存。
Sub Main()
Dim masterUnit As MeasurementUnit
Dim subUnit As MeasurementUnit
masterUnit.System = msdMeasurementSystemMetric
masterUnit.Base = msdMeasurementBaseMeter
masterUnit.Label = "m"
masterUnit.UnitsPerBaseDenominator = 1
masterUnit.UnitsPerBaseNumerator = 1
subUnit.System = msdMeasurementSystemMetric
subUnit.Base = msdMeasurementBaseMeter
subUnit.Label = "mm"
subUnit.UnitsPerBaseDenominator = 1
subUnit.UnitsPerBaseNumerator = 1000
ActiveModelReference.masterUnit = masterUnit
ActiveModelReference.subUnit = subUnit
ActiveModelReference.StorageUnit = masterUnit
ActiveModelReference.UORsPerStorageUnit = 10000
SaveSettings
End Sub
