【问题描述】
MicroStation的哪个版本支持哪种DWG/DXF版本格式,以及如何查找特定DWG/DXF文件的版本格式?
MicroStation version | DWG/DXF version |
| 23.00.01.44 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021/2022/2023/2024 |
| 23.00.00.108 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021/2022/2023 |
| 10.17.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021/2022/2023 |
| 10.16.03.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021/2022 |
| 10.16.02.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021/2022 |
| 10.16.01.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021 |
| 10.16.00.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021 |
| 10.15.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019/2020/2021 |
| 10.14.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.13.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.12.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.11.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.10.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.09.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.08.xx.xx | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018/2019 |
| 10.07.00.39 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013-2016 + 2018 |
| 10.06.00.38 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.05.00.40 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.04.00.46 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.03.00.30 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.02.00.39 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.01.00.13 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 10.00.00.25 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 08.11.09.919 | 14 + 2000/2000i/2002 + 2004/2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014/2015/2016 |
| 08.11.09.833 | 11/12 + 2000/2000i/2002 + 2004/2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014 2013/2014/2015(2016) > for 2016 a new separate "RealDWG 2016 Update" is available |
| 08.11.09.459 | 11/12 + 2000/2000i/2002 + 2004/2005/2006 + 2007/2008/2009 + 2010/2011/2012 + 2013/2014 (2013/2014/2015/2016 only with a separate "RealDWG 2016 Update" available) |
| 08.11.09.357/336 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 (+ 2013/2014 only with "RealDWG 2014" Update) |
| 08.11.09.292 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010/2011/2012 (+ 2013/2014 only with "RealDWG 2014" Update) |
| 08.11.07.446 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010 |
| 08.11.07.171 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 + 2010 |
| 08.11.07.115 | 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 |
| 08.11.05.17 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007/2008/2009 |
| 08.09.03.66/68 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005/2006 + 2007 |
| 08.09.02.77/82 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005 |
| 08.05.02.70 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005 |
| 08.05.02.56 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005 |
| 08.05.02.27/35 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005 |
| 08.05.01.25 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 + 2005 |
| 08.05.00.64 | 11/12 + 13 + 14 + 2000/2000i/2002 + 2004 |
| 08.01.02.15 | 2.6 + 9 + 10 + 11/12 + 13 + 14 + 2000/2000i/2002 |
| 08.01.01.09 | 2.6 + 9 + 10 + 11/12 + 13 + 14 + 2000/2000i/2002 |
| 07.01.05.03 | 2.6 + 9 + 10 + 11/12 + 13 + 14 + 2000/2000i/2002 |
| 07.01.04.10 | 2.6 + 9 + 10 + 11/12 + 13 + 14 + 2000 |
可以使用文本编辑器打开DWG/DXF文件来查找DWG/DXF格式版本。
每个DWG/DXF文件开头都有一个以“AC”开头的数字。以下是一些AC号码及其对应的AutoCAD版本:
AC number | AutoCAD versions |
| AC1032 | AutoCAD 2018, AutoCAD 2019, AutoCAD 2020, AutoCAD 2021, AutoCAD 2022, AutoCAD 2023 |
| AC1027 | AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD 2016, AutoCAD 2017 |
| AC1024 | AutoCAD 2010, AutoCAD 2011, AutoCAD 2012 |
| AC1021 | AutoCAD 2007, AutoCAD 2008, AutoCAD 2009 |
| AC1018 | AutoCAD 2004, AutoCAD 2005, AutoCAD 2006 |
| AC1015 | AutoCAD 2000, AutoCAD 2000i, AutoCAD 2002 |
| AC1014 | AutoCAD Release 14 |
| AC1012 | AutoCAD Release 13 |
| AC1009 | AutoCAD Release 11, AutoCAD Release 12 |
| AC1006 | AutoCAD Release 10 |
| AC1004 | AutoCAD Release 9 |
| AC1003 | AutoCAD Release 2.60 |
| AC1002 | AutoCAD Release 2.50 |
