Application
Open the Application page to create new applications, find existing applications or permits, and view messages about the system. If you need to test a trip, click the Route Evaluation Application tool link.
Starting a New Application
1. Navigate to the Application screen by clicking the Application link on the Main Link Bar.
2. Enter the Hauler Name or the DOT Number in the field provided; while you type, the system is already searching the database for matching information. Choose from the available options.
Note:  Most of the time, you will need to enter no more than three digits before the system begins presenting you with likely options.
3. From the Select a Permit Type, choose from the available options.
Find an Existing Application or Permit
The Application page opens.
2. On the Find an Existing Application or Permit panel, expand the top drop-down and choose from the available options.
3. Expand the Search by drop-down and choose from the available options.
4. Click the Submit button to open the desired application/permit.
Route Evaluation Application Tool
Use the Route Evaluation Application tool to plan and evaluate your route.
1. Click the Route Evaluation Application link to open an abbreviated application page.
2. In the Travel Dates area, click the calendar icons to choose both a From Date and a To Date.
3. In the Vehicle Configuration area, enter your Overall Vehicle Dimensions in the fields provided and supply the Number of Axles.
4. Slide the Progress Bar to Trip.
