Use the Advance Query page to create a custom searches to the database and then view the records that meet those parameters.
1. Navigate to the Advanced Query screen by clicking the My Admin link then choosing Advanced Query from the System Maintenance pane.
2. On the Advanced Query page, use the fields and dialogs to construct a query tailored to find either a single record or a small selection of records.
a. Start by expanding the drop-downs at the top of the page. If you are unaware of the Permit Type or Status, enter a date range.
b. Open additional User, Vehicle, and Route information options by clicking the icon [+] next to the most useful information group.
c. Under User Information, enter the name of a Carrier or Account in the field provided; while you type, the system is already searching the database for matching information. Choose from the available options.
Note: Most of the time, you will need to enter no more than three digits before the system begins presenting you with likely options.
3. Click the Search button to execute your custom query or click the Reset button (to clear the fields on this page).
