<?xml version="1.0" encoding="utf-8"?>
<ECSchema schemaName="MyECSchema" nameSpacePrefix="MyNSPre" version="1.0" description="MyDesc" displayLabel="MyDisLab" xmlns="http://www.bentley.com/schemas/Bentley.ECXML.2.0">
<ECClass typeName="MyClass" description="MyDesc" displayLabel="MyClassDisLab" isDomainClass="True">
<ECProperty propertyName="PropStr" typeName="string" />
<ECProperty propertyName="PropDou" typeName="double" />
<ECArrayProperty propertyName="PropArr" typeName="point3d" minOccurs="0" maxOccurs="unbounded" />
</ECClass>
</ECSchema>
如上所示的ECSchema中,在“MyClass”下的“PropArr”是一个数组类型的属性,我们在对元素添加“MyClass”类型属性时,可以参考如下代码对数组类型的EC属性赋值:
DgnECManager manager = DgnECManager.Manager;
FindInstancesScope scope = FindInstancesScope.CreateScope(ele, new FindInstancesScopeOption(DgnECHostType.Element, true));
FindInstancesScope scopeTemp = FindInstancesScope.CreateScope(Session.Instance.GetActiveDgnFile(), new FindInstancesScopeOption());
int verMaj = 01, verMin = 0;
IECSchema ecschema = DgnECManager.Manager.LocateSchemaInScope(scopeTemp, "MyECSchema", verMaj, verMin, SchemaMatchType.Latest);
if (ecschema == null)
return;
IECClass ecclass = ecschema.GetClass("MyClass");
if (ecclass == null)
return;
ECQuery query = new ECQuery(ecclass);
using (DgnECInstanceCollection ecInstances = manager.FindInstances(scope, query))
int cnt = ecInstances.Count();
if (cnt > 0)
foreach (IDgnECInstance dgnEcIns in ecInstances)
var ecVal = dgnEcIns["PropArr"];
if (ecVal.IsArray)
IECArrayValue ecArrVal = ecVal as IECArrayValue;
var ecArrItemVal = ecArrVal[0];
ECDPoint3dValue ecDPtVal = ecArrVal[0] as ECDPoint3dValue;
for (int i = 0; i < ecArrVal.Count; i++)
ECDPoint3dValue ecPtVal = ecArrVal[i] as ECDPoint3dValue;
if (null != ecPtVal)
MessageBox.Show(ecPtVal.DPoint3dValue.ToString());
return;
DgnECInstanceEnabler instanceEnabler = DgnECManager.Manager.ObtainInstanceEnabler(Bentley.MstnPlatformNET.Session.Instance.GetActiveDgnFile(), ecclass);
StandaloneECDInstance instance = instanceEnabler.SharedWipInstance;
instance.SetString("PropStr", "MyVal");
instance.SetDouble("PropDou", 200.0);
IECPropertyValue iECPropVal = instance["PropArr"];
IECArrayValue iECArrVal = iECPropVal as IECArrayValue;
iECArrVal[0].NativeValue = new DPoint3d(1, 2, 3);
iECArrVal[1].NativeValue = new DPoint3d(4, 5, 6);
iECArrVal[2].NativeValue = new DPoint3d(7, 8, 9);
instanceEnabler.CreateInstanceOnElement(ele, instance, false);
