API Guide - Credentials
  Product(s): AssetWise Inspections Server
  Version(s): N/A
  Environment: all
  Area: API
  Subarea: N/A
Usage
All currently supported endpoints can be viewed and tested at
https://SITENAME-api.bentley.com/swagger/index.html  (replace SITENAME with your sitename, i.e. MyStateDOT)
Generate API credentials at https://SITENAME.bentley.com/api_management.aspx
username = keyname
password = key
self-hosted users only
Steps to install new API
Server pre-requisites:
Configuration
Update appsettings.json values with the values found in the web.config of the main website
Note: Be sure to escape any \ to \\
