| Product(s): | Exor Spatial Manager, Locator, TMA | ||
| Version(s): | |||
| Area: | Other | ||
| Subarea: | |||
| Original Author: | Pano Voudouris, Bentley Technical Support Group | ||
This error may occur either when editing in Spatial Manager or when using locator with different product-specific forms. The following is an example of an error message when trying to send a TMA notice:
tma-0093 unable to send notice, error in API (tma_works_api.process_pase_coords) domain index is marked LOADING/FAILED/UNUSABLE
The spatial index in one or more spatial tables has been invalidated.
Run the following script to determine which spatial tables have the invalid index:
select index_name, table_name, owner, status, DOMIDX_status, domidx_opstatus from all_indexes where DOMIDX_opstatus is not null and DOMIDX_opstatus != 'VALID';
This will return a list of table and index names eg.
INDEX_NAME |
TABLE_NAME |
OWNER |
STATUS |
DOMIDX_STATUS |
DOMIDX_OPSTATUS | |
NCC_PARISHMB_IDX |
NCC_PARISH |
VALID |
VALID |
FAILED | |
INSPECTOR_SECTORSMB_IDX |
INSPECTOR_SECTORS |
VALID |
VALID |
FAILED | |
GEOM_TABLEMB_IDX |
GEOM_TABLE |
VALID |
VALID |
FAILED | |
TMA_NONSWA_LOCS_SDO_SPDIX |
TMA_NONSWA_STR_LOCS_SDO |
VALID |
VALID |
FAILED | |
ESU_SPIDX |
NM_NSG_ESU_SHAPES_OLD |
VALID |
VALID |
FAILED | |
TMA_PHASES_SDO_SPIDX |
TMA_PHASES_SDO |
VALID |
VALID |
FAILED |
In this example, the error was displayed when working with TMA, so the most likely culprit(s) are the TMA tables (TMA_PHASES_SDO and TMA_NONSWA_STR_LOCS_SDO)
In order to recreate the index go to the GIS Layer tool form, get this table and press the [Rebuild Index] button as shown in the screenshot below.
