| Product(s): | Exor NET Core/Network/Assets | ||
| Version(s): | 4.5.0.0 | ||
| Area: | Administration | ||
| Subarea: | N/A | ||
HIG1862 Admin units - report, fails with REP-300: CONNECT BY clause required in this query block FROM ==> nm_admin_units_all
Apply work around below to database(s).
The reports have SQL whcih makes use of the LEVEL pseudo column within a query block that doesn't have a connect by. At some stage, the rules governing the use of the pseudocolumn have changed. As a workaround, use the Oracle option _allow_level_without_connect_by to re-engineer compatibility using:
Metalink note:
Use _allow_level_without_connect_by to Revert Back to 9i Hierarchical Query Behavior [ID 271939.1]
explains setting a parameter to allow the older behaviour of using level without a connect by.
alter system set "_allow_level_without_connect_by"=true scope=both;
