| Product(s): | EXOR SM SPATIAL MANAGER | ||
| Version(s): | ALL | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
After creating a GIS layer (or Layers) using the GIS0020-GIS Layer Tool, the layer(s) are not visible in the SM Exor Groups Tree view.
Go to the GIS0010-GIS Themes form and make sure the theme or themes you want displayed in SM have roles assigned to them. If not, add the appropriate roles. You can the go back to SM, right click on an empty space in the Exor Groups tree view and select [Refresh]. The new layer(s) should appear in the tree.
