| Product(s): | Exor Network Manager | ||
| Version(s): | N/A | ||
| Area: | CSV Loader | ||
| Subarea: | |||
| Original Author: | Sarah Williams, Bentley Technical Support Group | ||
When loading a particular asset type through the CSV Loaders, I get an error:
NET-0339: You do not have permission to update this record
This error is probably due to role or admin unit issues.
Check that the user is assigned the same admin unit as the asset being created, or a parent admin unit of the asset's admin unit. The user's admin unit can be found in the Users form (HIG1832).
