Reports - The specified environment is invalid
  Product(s): EXOR STRUCTURES MANAGER
  Version(s): 4.7.0.1
  Environment:  N/A
  Area:  Reports
  Subarea:  N/A
Trying to run reports causes the following error to appear:
rep-56107 The specified environment id <reportID> is invalid for job type report in the command line
This error appears when the system is unable to find the environment ID, which is specified within the rwserver.conf file on the reports server.  Ensure that the environment ID specified in the product option REPURL matches exactly (including case) against the configuration file.
Comments or Corrections?
