| Product(s): | Exor Network Manager | ||
| Version(s): | 04.07.00.01 | ||
| Area: | Other | ||
| Subarea: | N\A | ||
| Original Author: | Sarah Williams, Bentley Technical Support Group | ||
How to start the Exor application on a particular form other than the standard Favourites menu
Having identified the form you want the application to bring up when the user logs in, use the Help / About Current Form menu option to get the module ID.
