| Product(s): | Exor TMA Noticing Manager | ||
| Version(s): | 04.07.00.15 | ||
| Area: | Works | ||
| Subarea: | N\A |
How to set up the Street of Interest or Lane Rental check box on the TMA Works form (TMA1000)
This check box is used to identify streets of interest that the user needs to be aware of. It is frequently used by Utilities to identify lane rental streets but can be customised according to the users' needs.
3. Ensure that the process TMA Evaluate Applied Notices is scheduled. You can check this in the Process Monitor form (HIG2520). Choose TMA Evaluate Applied Notices in the drop down list in the Restrict box at the top of the form, then run a query. If the process is scheduled you’ll see last run and next run dates in the record that is retrieved, and the job state should read “Scheduled”. If the query brings back no results the process will need to be scheduled. Details on how to do this can be found in the Exor General Admin Guide section 2.11.
The Exor TMA Admin Guide and Exor General Admin Guide can both be found here:
https://exor.assetwiseonline.bentley.com/Assetwise/docindex.asp?docs=4700-product
| Original Author: | Sarah Williams |
