Product(s): | Exor MapCapture (ESRI) | ||
Version(s): | N\A | ||
Environment: | Windows 8 | ||
Area: | N/A | ||
Subarea: | N\A |
Error message appears in MapCapure
Microsoft .NET Framework
Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and attempt to continue.
Cannot Access a disposed object.
Object name: 'INodeTreeView'.
Reinstall .NET framework.
Original Author: | Kristijonas Nalivaika |
