ORA-20041:Error Occured While Creating eB DOCS Entry: ORA-06508:PL/SQL: could not find program unit
 Product(s):Exor MapCapture
 Version(s):N\A
 Environment:Windows XP 64 bit
 Area:Inspections
 Subarea:N\A
Problem Description
Loading an Inspection fails with error message
ORA-20041:Error Occured While Creating eB DOCS Entry: ORA-06508:PL/SQL: could not find program unit being called
Steps to Resolve
The cause could be an unstable program unit nm3_doc_man
Please contact Bentley Support to recompile the package.
When this has been confirmed, query back the Inspection Batch in the Maintenance Inspection Summary\Error Correction form ( MAI4405), highlight the inspection that failed by selecting and then choose the Re-Submit Inspection button.  The module previously failing required should then be available to complete the task
 Original Author:Clive T
