| Product(s): | Exor Spatial Manager | ||
| Version(s): | 4.x | ||
| Area: | N/A | ||
| Subarea: | N/A |
On creating a new road section element using Spatial Manager the system throws up ORA-06512 error message.
More details about the error in Spatial Manager error log file :
DATETIME: 2017:12:14 - 8:17:47, DLLVERSION: 4.4.x.x Build (0)]
Procedure: StoreElement clsParameters.cls Line : 570
Error Number: -2147217004
Error Description: NM3 API Oracle Error
SQL execution error, ORA-20001: HIG-0067: Record not found: nm_elements (NE_PK)
ne_id => 72953
ORA-06512: at "HIGHWAYS.HIG", line 1464
ORA-06512: at "HIGHWAYS.NM3GET", line 4692
ORA-06512: at "HIGHWAYS.NM3NET", line 2266
ORA-06512: at "HIGHWAYS.NM3NET", line 1641
ORA-06512: at "HIGHWAYS.NM3NET", line 1995
ORA-06512: at line 1
An user is trying to set the same section link number as it was used in the past and that link is end-dated in database. The user should specify another section link number.
| Original Author: | Renatas |
