Product(s): | Exor UKPMS | ||
Version(s): | 04.05.00.00 | ||
Environment: | N/A | ||
Area: | HMDIF Load | ||
Subarea: | N/A |
When an user runs UKO030 Automatic Pass the error is shown in Spooled Output:
UKP030: INFO Processing file – dvi1718_23-OCT-2017.hmv
INFO: File validation complete
UKP030 Oracle Error Encountered
UKP030 SQL-02112 SELECT..INTO returns too many rows
This error occurred in Function: get_section_label
Connect into Oracle database and run the sql command:
select * from ukpms_sect_label;
there must be only one row/record in the output of this command, if there is more than one record please, remove the redundant record.
Original Author: | Renatas |
