| Product(s): | Exor TMA | ||
| Version(s): | 4.7.0.1 | ||
| Area: | Works | ||
| Subarea: | N/A |
Unable to select the Promoter/Contractor contact in the Phase Details tab
In order to be able to select the contact from either the Phase Details or Signals tab, you need to assign contact name in TMA0010 and declare it as Contractor/Promoter.
1. Open the contacts form (TMA0010).
2. In Contacts select the contact name which you want to assign contact role for.
3. Click on '>' button in the middle.
4. Further Details and Contact Roles will get displayed.
5. In Contact Roles, select the Organisation, District and Role
6. Click Save and exit the form.
| Original Author: | Jyoti Patil |
