| Product(s): | Exor Network Manager | ||
| Version(s): | 4.5.0.0 and above | ||
| Area: | Locator | ||
| Subarea: | N/A |
When exporting results in CSV format from Locator (NM0572), nothing happens. There is no error message and the file is not created.
Click on the ‘Tools’ button on the top right-hand side of any Internet Explorer page as you look at it and select ‘Internet Options’ from the drop down box
Click on the ‘Security’ tab. Click on the ‘Trusted Sites’ and it will highlight.
Then click on the button marked ‘Custom level… ‘
This will take you to the ‘Security Settings – Trusted Sites Zone’. Scroll down till you reach the Downloads section.
When you arrive at the Downloads section, You will see that the Automatic prompting for file downloads has been set to ‘Disable’ – you should change this to ‘Enable’
You will be prompted with a warning – click ‘Yes’.
Once returned to the Security screen, click ‘Apply’, then ‘OK’, then close
with cnt as ( SELECT COUNT(*) + 1 fnum FROM nm_upload_files WHERE name LIKE 'NM0572'||'%') select name from nm_upload_files, cnt where name LIKE 'NM0572_'||FNUM || '%';
To correct the problem found above:
delete nm_upload_files where name LIKE 'NM0572%'; commit;
7. Run the query below to see how many LOCATOR_EXPORT$$xx temporary tables have been created in the database.
select * from all_objects where object_name like 'LOCATOR_EXPORT%' and owner = 'HIGHWAYS';
if there are up to 99 (LOCATOR_EXPORT$$99) tables then delete them from the database and try to do asset export again.
8. Contact Bentley Support for assistance
| Original Author: | Elisabeth Pry |
