| Product(s): | Exor TMA Noticing Manager | ||
| Version(s): | 04.05.10.02 | ||
| Area: | Works | ||
| Subarea: | N/A | ||
If the .net wsdl file is required, the following steps must be followed in order to view the details.
1. Enter the url: http://<hostname>/<application name>/EToN.svc?wsdl
<hostname> is the name of the server where IIS is installed.
<application name> is the name of the application defined within your IIS server configuration.
