| Product(s): | Exor TMA Noticing Manager | ||
| Version(s): | All | ||
| Area: | Transactions | ||
| Subarea: | N/A |
User received an Initial Notice which declared a Type 4 Street and the notice was loaded without an error.
TMA Works should only reference type 1 or 2 streets from the NSG gazetteer, as per EToN regulations.
TMA Manager has validation in place that doesn’t allow a TMA user to select a type 3 or 4 street for a new works record, however other software appears to allow them to be used. When a user enters a new works record in TMA manager, type 3 and 4 streets are not seen in the street selection form, even if they are added to a street group.
When notices declaring a type 3 or 4 street are received they are loaded by TMA Manager with the following warning attached:
USRN defined on notice must be of NSG Type 1 or 2
By default this validation message is set to a warning to allow the notice to load regardless. The software does this so that a street authority doesn’t miss seeing the notice for coordination or inspecting the works etc.
If you don’t want notices against type 3 or 4 streets to load then you should change this validation to be an Error rather than a Warning. To do this see form TMA2050 Notice Warnings and edit warning number 151.
| Original Author: | Bentley Technical Support |
