STP: Road Construction Data form FRM-40735: POST-QUERY trigger raised unhandled exception ORA-06502
 Product(s):Exor Schema Manager
 Version(s):N/A
 Environment:4.5
 Area:Road Construction
 Subarea:N/A
When selecting the Details tab on the Road Construction Data form, an error is returned when selecting a layer number:
  1. Go to Asset Metamodel form
  2. Query back the asset (in our case it is PLAY).
  3. Click on Attributes tab and check the Display Width fields value must be set to max+1 length of Meaning field’s domain assigned to this attribute.
 Original Author:NT
