| Product(s): | Exor Core / Network / Document Manager | ||
| Version(s): | 4.2.1.0 | ||
| Area: | Locator | ||
| Subarea: | N/A | ||
When you try to order results by a string field in the Locator form you get an 'Invalid number' error.
This is probably because the sorted column in the underlying spatial view is been defined as a VARCHAR whereas in the the Asset Metamodel is defined as a number field.
