Object variable or With Block variable not set when trying to display the Streets form
 Product(s):Exor Street Gazetteer Manager
 Version(s):All
 Environment:N/A
 Area:Gazetteer
 Subarea:N/A
 When attempting to display the Streets forms, system displays an error:
Object variable or With block variable not set
 This error is caused by the dXEditrs.dll file not being registered in the Windows registry. The file is located under <SM_Install_folder>\bin e.g. c:\Exor\SM\bin
To register the file open a command prompt and issue the following command:
Regsvr32 c:\Exor\SM\bin\dXEditrs.dll
 Original Author:Pano Voudouris
