| Product(s): | Exor NSG Street Gazetteer Manager | ||
| Version(s): | 4.5.0.0 | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
User is not able to delete/remove ESU within USRN in NSG Gazetteer form. No pop-up error message appears, but on the bottom You will see a message:
"Cannot delete master record when matching detail records exist"
The error means that there are child records for ESU: Highway Dedications (HD) or One way exemptions (OWE). Please follow these steps:
1. Select ESU which You want to remove.
2. In HD/OWE section: click on CLOSE button.
3. SAVE form.
4. Repeat steps 2-3 if You have more HD/OWE records.
5. Select ESU.
6. Click red cross to delete the record.
7. SAVE form.
