Product(s): | Exor UKPMS | ||
Version(s): | 04.07.00.01 | ||
Environment: | N\A | ||
Area: | Survey Load | ||
Subarea: | N\A |
FRM-40734: internal error: PL/SQL error occurred
Error occurs when the user clicks to bring up file browser window to select HMDIF file to pre-process in any of the pre-processors.
Check values of user options REPCLIPATH and REPOUTPATH. They should point to the reports output location on the application server, as the application server sees it.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0091239
