Product(s): | Exor Document Manager | ||
Version(s): | 4.7.0.0 | ||
Environment: | N\A | ||
Area: | Create | ||
Subarea: | N\A |
ORA-04062: signature of package "NM3GET" has been changed.
When trying to use the Associated Documents form (DOC0120), it returns the following error:
This message appears after Network Manager Fix 24 was installed. But a new DOC0120.fmx file was not copied to Exor\Bin directory. Please check the DOC0120 form version should be 5.1.1.0 and nm3get version and body version are 2.22.
https://communities.bentley.com/products/assetwise/exor/w/wiki/8668
Original Author: | NT |
