| Product(s): | Exor Maintenance Manager | ||
| Version(s): | 4.3.0.0 | ||
| Area: | Budgets | ||
| Subarea: | N/A | ||
Want to stop users from selecting a budget on a works order. The budgets are set yearly and I don’t think they can be end dated.
Created a new DUMMY GROUP with no memberships.
Using sql, assigned existing budgets no longer wish to use to the new DUMMY GROUP.
Any section selected on a future works order post doing above ,will then not find the budgets , as the dummy group has no section memberships so nothing to match against.
Please contact Bentley TSG for sql to achieve.
